Truck died and won't restart - Ford Powerstroke Diesel Forum
Old 11-17-2012, 01:17 AM
I was driving through town the other day and my truck died on me. Changed out the cam and crank positioning sensors and still won't start. I know I have one injector going bad and plan to change it. I am getting no codes. I am in desperate need of help. I was hoping for some feedback. Also hoping someone could point me in the right direction as to how to check my FICM. If it matters I am running 225cc injectors with an II silver 64 turbo.
Old 11-17-2012, 01:40 AM
Illiana Chapter Director
What year truck? Have you checked fuel pressure?
Old 11-17-2012, 01:46 AM
It is a late 2004. No I have no monitor to check that. I can hear the pump running. I am running a 190 gph FASS fuel system.
Old 11-17-2012, 01:51 AM
You need to get an adapter and gauge to get a fuel pressure reading. Pump may be running but not giving enough pressure. You can find a link here to check your FICM. Swamp's Diesel Performance - Diesel Performance Parts and Products. If that checks out you're gonna have to have a way to monitor your ICP and IPR and see if you have a HPO leak.
Old 11-17-2012, 01:55 AM
What would be the best monitor to get. I am new to the diesel world and haven't really done much with it yet.
Old 11-17-2012, 01:59 AM
For the money and capability, Auto Enginuity is awesome. I've had mine for a month and it's paid for itself more than once already.
Old 11-17-2012, 02:02 AM
Where can I get one of them at? Will that show me fuel pressure and anything else that's wrong even if it won't show a code on the computer? I am getting oil pressure according to the gauge in my cluster.
Old 11-17-2012, 02:18 AM
It won't show fuel pressure. The gauge in your cluster is for low pressure only. Sounds like you have a high pressure issue. Unplug your ICP sensor and see if it starts.
Old 11-17-2012, 02:20 AM
Got mine here. Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
Old 11-17-2012, 02:26 AM
Ok and if it starts just replace that then I should be in good shape?
