injection pressure too low, code p2290 - Page 4 - Ford Powerstroke Diesel Forum
  #31 (permalink)
Old 12-09-2012, 10:13 PM
How high should the desired pressure go at WOT?
  #32 (permalink)
Old 12-10-2012, 05:16 AM
Honestly "desired" isnt what you really want to look at. The key here is you only have 3000 psi WOT... It should be closer to 4000.
Are you running a tuner on the truck? Custom tunes? Some tunes can affect ICP as its displayed by scan tools.
  #33 (permalink)
Old 12-10-2012, 11:24 AM
There is a tune on the truck but not sure which one cause it was tuned before I bought it.
When I slowly push on the throttle the pressures are about the same all the way til about half way down and I see pressure of 3600-3700 and 70% on ipr. Then after half throttle when it really takes off the dsd pressure goes to 4600 and actual drops to around 3100 and ipr is 85%.
Is it possible that it is just the tune?
  #34 (permalink)
Old 12-10-2012, 12:03 PM
The new icp sensor and pigtail will be installed tomorrow. Sensor was leaking. New one came today and pigtail will be in tomorrow.
  #35 (permalink)
Old 12-12-2012, 12:56 PM
installed new icp sensor and pigtail today and no change.
  #36 (permalink)
Old 12-12-2012, 10:03 PM
would be real nice if you could return to stock and see what that does..
  #37 (permalink)
Old 12-12-2012, 11:31 PM
I was thinking about doing that but I wanna buy a tuner first. Any suggestions on a good tuner??
  #38 (permalink)
Old 12-16-2012, 09:08 AM
Anyone have any ideas on what may be causing this pressure issue, could it just be the tuner that was used
  #39 (permalink)
Old 12-17-2012, 05:57 AM
Sounds like a typical tuning quirk... My 2c is to return the truck to stock and go from there.
  #40 (permalink)
Old 12-30-2012, 02:34 PM
I am looking at getting a sct tuner which one should I get the sf3 or the x3? I found an x3 for $100 would that be a good one to get?
