Changing coolant question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-14-2012, 03:54 AM Thread Starter
I'm wrapping up some work on my Ex (EGR delete & oil cooler) and getting ready for coolant. I've looked all over including local CAT dealer. All I can find is pre-mixed 50/50 EC-1. Is there any tricks to getting more water out of cooling system so I could just fill with pre-mixed or is it necessary to use concentrated to get a suitable mixture? Thanks.
2004 Excursion 6.0 Limited
Tinted Windows, Cab Lights, Husky-Liner Floor mats, MBRP 4" Stainless turbo-back, Insight CTS, ebay EGR delete, dFuser coolant filtration, Cat EC-1 coolant, SCT Xcal2, Warn manual hubs
regans5 is offline
post #2 of 6 Old 11-14-2012, 04:26 AM
as far as i know, International Harvester service centers have the 100% dose. - good stuff
01 7.3 f350 CC/SB - chipless w/3:73s
TrueCool Transcooler
FTVB
Gauges
AIS
Walker BTM
Bilstien 5100s
Soft top
daveyburt is offline
post #3 of 6 Old 11-14-2012, 04:31 AM Thread Starter
I'll google that in my area. Thank you.
regans5 is offline
post #4 of 6 Old 11-14-2012, 08:34 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 548 Post(s)
Garage
Are you sure guy at Cat dealer knew what he was talking about?
I got mine at the Cat dealer it was straight concentrate, have a jug at home and can give you the # if you want it.
One note I did put in Cascade before I switched to the ELC to make sure it was clean and washed out. The coolant that Cat sells is much thicker than aftermarket ELC-1 not sure if thats good or bad, but there is a difference none the less.
Pull at least the driver side block plug out for draining
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is online now
post #5 of 6 Old 11-14-2012, 11:27 AM Thread Starter
That's what he said. They had gallon jugs and 5 gallon buckets of 50/50 so I bought 2 buckets. They also had gallon jugs of concentrate but it wasn't EC-1. I was thinking about just removing the thermostat and pulling the upper radiator hose off and pouring it in until I see the water come out and change to coolant. And yes I'll drain the radiator and pull driver's side plug. Do you think that would be ok?
regans5 is offline
post #6 of 6 Old 11-14-2012, 04:20 PM
mhatlen's Avatar
Quoted: 548 Post(s)
Garage
I know its recomended to add straight then distilled, if you already bought 50/50 I would take the time to drop the starter and pull that block plug too.
I would also pull the hose off heater core shut off valve as well as where it is supplied from which is the 3/4 upper hose on the Y below coolant tank and blow it dry with compressed air. Then you will be empty and what you pour in will be all your fluid.
If you are switching from Gold to ELC-1 make sure to flush it well. When I switched I pulled thermostat and drained all fluids out refilled with DI water and added 1/2 cup of cascade and went for a twenty mile drive. Drained and flushed 3 times with DI water, last drain poured in 3-1/2 gallons of CAT-1 and arond 3-1/2 Distilled water. Still looks weird seeing Blood Red in the coolant tank, but all is well and feel it was a smart thing to do for the coolers.
Just drain it all out and use what you have.
7" Icon/Carli Lift
Atlas40
4" SS exhaust
58K Miles on it
