misfire? - Ford Powerstroke Diesel Forum
Old 11-13-2012, 01:01 PM
misfire?
Hey whats up everyone? I have a 2003 6.0 with 144k miles. I noticed when I first start the truck in the morning it puffs out white smoke and starts kinda rough but smooths out quickly. The past couple nights I plugged my truck in with it being below freezing and it starts right up no problem but still puffs a little smoke not as much as not plugging in. I also noticed If i give it extra throttle(after warmed up of course) It almost seems its misfiring also. Is this a symptom of failing glow plugs? To my knowlege they have never been changed. I appreciate the help everyone.
James
Old 11-13-2012, 01:04 PM
also there is no Check engine light
Old 11-13-2012, 02:28 PM
First, you need a monitor, second, our trucks store codes. The light will not always illuminate when there is a problem. Load test your batteries, then perform the ficm check procedure if your batteries are ok. Bad batteries kill ficms.
Sent from my phone that somebody didn't help me get.
Old 11-13-2012, 04:22 PM
Yep
I suspect your FICM as well. Look up my post for an explanation of what to look for. If that's not it, look up stiction and solutions to that.
Good luck!
Old 11-14-2012, 01:21 PM
I will check the ficm. I replaced the ficm last winter I believe. I hope its not the ficm again. I appreciate the replies and that is where I will start. Im glad its not an obvious HPOP problem. I was dreading that.
Old 11-14-2012, 01:40 PM
This is essential......Write Up: Monitoring the 6.0L PSD.
Old 11-14-2012, 04:02 PM
Monitoring
Best of luck! Can't agree more about the monitoring. I have been real happy with my Dashboss monitoring system. You would be able to diagnose your FICM right from the driver seat if you had that. I have been able to pinpoint a few problems since I got mine a month or two ago.
