dripping Injectors?? - Ford Powerstroke Diesel Forum
Old 11-12-2012, 02:05 PM
so before the truck is fully warmed up i get a large puff of white smoke when i stop at a light, i have smelled the haze and it is fuel. i am going to be doing head studs in a few weeks and i wanted to know if i can tell and injector is bad or dripping if i look at it. i have had all the Injector tests done by the computer and it all comes back good
Old 11-12-2012, 02:27 PM
It's not good to run it like that, that can damage pistons, most especially if the tip is cracked, and a piece comes loose.
Sent from my phone that somebody didn't help me get.
Old 11-12-2012, 02:42 PM
You can useually tell if the tip is plum gone, but whether it is dripping or spraying correctly can only be done with special equipment [big big bucks] most injector rebuild companies (independants) don't own one. They exchange out with rebuilts that they get from even larger companies.
Old 11-12-2012, 02:45 PM
I guess if it's cracked fuel would likely show up in the oil, with heavy smoke?
Old 11-12-2012, 03:13 PM
a little heavy but only when truck is like 1/4 warmed up and it idles for a few secconds. when once i take off its gone
Old 11-12-2012, 03:14 PM
and no fuel in the oil
Old 11-12-2012, 03:15 PM
its been doing it for over 30000 miles so i think if something was really bad it would have already happened, its just a little embarrassing sometimes. lol
Old 11-12-2012, 03:29 PM
Have you checked your ficm voltages?
Old 11-12-2012, 03:38 PM
yup. i got a swamps high volt, got around 50v
Old 11-12-2012, 04:24 PM
Does the truck hesitate/spudder when taking off?
