2007 f350 6.0 no start - Ford Powerstroke Diesel Forum
post #1 of 33 Old 11-11-2012, 01:08 AM Thread Starter
roche837's Avatar
Quoted: 6 Post(s)
Garage
Feedback Score: 4 reviews
Have a friend whos truck quit running, showing a p2291 ICP Too Low {while cranking} showed about 740 kpa which is roughly 108 psi, i found his oil filter cap to be a aftermarket one with no gasket and appears to be leaking. I am definitely going to start there this could cause a no start correct? ICP is easily accessable compared to mine which was buried under the turbo on my 03, the connector is not oil soaked.
Guy is very hard on his truck oil looks like cake batter, so i am going to start with a ford cap and filter and some fresh oil, anything you 05-07 gurus have to add im more familiar with the 03-04 motors
Unsure if the STC fitting has ever been messed with might need an oasis report.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #2 of 33 Old 11-11-2012, 04:40 AM
southend's Avatar
You are on the right path, dummy plugs, stc, and stand pipes are a problem on the 05-06, for sure. Can you read ipr?
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 33 Old 11-11-2012, 07:22 AM
Cake batter!! what color? You could have moore issues than you think if that is coolant in the mix.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #4 of 33 Old 11-11-2012, 07:27 AM
southend's Avatar
Hehe, I kind of figured he was exagerating........maybe not. Surely that truck would have self destructed a long time ago?
southend is offline
post #5 of 33 Old 11-11-2012, 07:50 AM
Actually I have seen em hang together with oil the consistancy of p-nut butter but the damage/cost was tremendous. Now how they hung together is beyond me LOL.
These were mainly industrial grade engines tho they were built to last forever I do not think a 6.0 block would survive those extreme conditions.
post #6 of 33 Old 11-11-2012, 12:51 PM Thread Starter
roche837's Avatar
Quoted: 6 Post(s)
Garage
I did not see any oil in the degas bottle, the oil is seriously black and very thick, not even sure if its 10-40 hes a semi driver so who knows what he has used, and i dont believe its been changed in many miles.
i cannot read IPR with the scan tool i have unfortunately, hoping i can command it closed so i can put air to the ICP port to listen for leaks
roche837 is offline
post #7 of 33 Old 11-11-2012, 01:20 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
100 psi is a pretty big leak. That's STC range when it pops loose. If it's possible do an air check on it
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #8 of 33 Old 11-11-2012, 03:15 PM Thread Starter
roche837's Avatar
Quoted: 6 Post(s)
Garage
Thats what im going to try as long as my scan tool can close the IPR which im unsure of. I have the adapter for the ICP port i just need to rig up an air line to it.
roche837 is offline
post #9 of 33 Old 11-11-2012, 03:16 PM Thread Starter
roche837's Avatar
Quoted: 6 Post(s)
Garage
Do you have to pull the intake to get the HPOP cover off on these years?
roche837 is offline
post #10 of 33 Old 11-11-2012, 04:04 PM
southend's Avatar
I dont think so, although the right side bolts are difficult to get to.
southend is offline
