loss of power - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-09-2012, 09:49 AM Thread Starter
loss of power
I just completed a oil cooler swap in my 04 6.0. The engine sounds great, I can rev it up and down with no stumbles. When I try to test drive thou it has very poor power, getting around 8 mpg (according to scan gauge) and shifts hard and shakes terribly at speed. Im not getting any codes popping up don't really know where to start looking first. I have the scan gauge so if any perimeters are needed to try to narrow this down please say and ill get them.
please any help pointing me in the right direction would be appreciated
Rod.stan is offline
post #2 of 7 Old 11-09-2012, 01:16 PM
check for a turbo leak it will do all that you posted hows your icp and ipr readinds also
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #3 of 7 Old 11-09-2012, 04:16 PM
southend's Avatar
Make sure all your ficm connectors are seated well.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 7 Old 11-09-2012, 06:54 PM
Are there any tranny paremeters that it can read?
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #5 of 7 Old 11-12-2012, 04:51 AM Thread Starter
my ICP is good @ 700-1400
and my IPR seems good @ 25 at idle
Im not finding any turbo leaks but is there any good tips to help check for leaks that I just can't see/hear
Rod.stan is offline
post #6 of 7 Old 11-12-2012, 05:16 AM
southend's Avatar
Are you using motorcraft filters with matching caps? You may want to check fuel pressure, it may have just started and is unrelated to your oil cooler replacement. Do you have the updated blue spring in the fpr? With good hpop readings, I would investigate fuel. Check all your injector connectors.
southend is offline
post #7 of 7 Old 11-12-2012, 09:57 AM
I use that thin hvac tape to find them
03 f-250
blue spring
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
tatertot is offline
