Thermostat stuck open? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-08-2012, 06:47 AM Thread Starter
Korx's Avatar
So I rarely see my EOT and ECT reach 180 degrees, even on 45+ minute trips.
I'm not sure but would this mean my thermostat is stuck open? Everything I've ready says that the thermostat only effects the ECT not the EOT.
Not sure if this is true or not. I know its not all that hard to replace nor expensive I just want to get a second opinion first and make sure the symptoms I'm seeing lead to a stuck open thermostat not something else like a bad egr cooler or oil cooler.
I am getting heat out of my vents once it gets up to around 150-170.
Usual temps are around the 170's. So I'm not sure. :screwy:
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #2 of 10 Old 11-08-2012, 08:39 AM
Term3's Avatar
Pretty common for the thermostat to fail open. Easy, cheap thing to change out.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 10 Old 11-08-2012, 05:24 PM Thread Starter
Korx's Avatar
Changed it today. Ford didn't have one in stock, so I just got one from NAPA for $29. Seems to have done the trick.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #4 of 10 Old 11-08-2012, 05:40 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Get one from Ford and change it again. Ford is the only thermostat that will fail open. If the one you put in fails, it will fail closed and cause it to get hot.
dhanna6powerstroke is offline
post #5 of 10 Old 11-08-2012, 05:42 PM Thread Starter
Korx's Avatar
I plan to, I just needed one in a hurry and ford didn't have one. I plan on getting a new one when I order all my other parts from Trousley.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #6 of 10 Old 11-08-2012, 05:54 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
hes 1000% correct change that baby out!
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #7 of 10 Old 11-08-2012, 07:16 PM
Term3's Avatar
You you want to buy cheap parts buy a Dodge.
Term3 is offline
post #8 of 10 Old 11-09-2012, 03:11 AM Thread Starter
Korx's Avatar
For the third time. I plan on replacing it with a ford one, my local Ford dealer was out of stock.
The napa part is hardly even any cheaper than a Ford one.
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #9 of 10 Old 11-10-2012, 04:19 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
*******STUPID QUESTION ALERT******* U say they fail open and that seemed to be the issue here. Does the T-stat truely stay's open even after you take it out and it cools or does it just open up too early and never close?
I guess what Im asking would a visual confirm the stuck open t-stat?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 10 Old 11-10-2012, 05:00 AM
If it is indeed stuck open you can visually see it when it is taken out, the seat will be unseated and you can see daylight between the mateing surfaces.
You can even test it to see what temp a thermostat is actually opening.
You get a heatable container, a mercury thermometer and a heat source. Fill container with water place the thermostat and thermometer in container and heat the container while observeing the stat and the thermometer. When you see it open check the temp reading and that is your opening temp. Just an old school test.
Caution: If useing glass container use something like a pyrex bowl, something designed to be heated at high temps or it can shatter.
NOTE: buy your own bowl wives do not take kindly to useing their cooking ware for experiments.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
