Hard start, rough idle, then fine after up to temp! - Ford Powerstroke Diesel Forum
Old 11-05-2012, 09:45 AM
Exclamation Hard start, rough idle, then fine after up to temp!
I have a 2006 f350 6.0.
It has a rebuilt ficm, dummy plugs
I had a edge evolution on it and took it of an sold it two days ago( sct is on its way). When I took it off and sold the chip, I went to start my truck and it started prefect then started to idle badly. Sounded like a bad lope tune. So i shut the truck off and tried restarting. I got the same result. So I pulled the truck forward and after about 1 min the truck ran fine after it got to temp.
So then I let the truck sit for 2 days not driving it and not plugged in.
I went to go start the truck and it would not start. Cranked and cranked and cranked. White smoke like crazy. So I plugged the truck in and went inside for 2 hours and came back out and tried to start it. Cranked right up but started the bad lope again then after it got to temp it ran fine
Engine light is on now and I haven't got the codes read yet
These symptoms happend right after I unplugged my edge. So I'm guessing it has to do somthing with this. Please help me!
Should I get my truck flashed? Should I wait till my sct gets here?
I've also heard tht it may be my batteries??
Old 11-05-2012, 01:27 PM
Bad batteries kill ficms, even rebuilt ficms. Load test your batteries.
Sent from my phone that somebody didn't help me get.
Old 11-05-2012, 03:26 PM
Will do. Thanks
But it seems odd that it would happen the second I took off my edge.
Before I took the edge off I cranked up perfect!
Anybody else?!?!
Old 11-05-2012, 05:10 PM
It sounds like your spool valves are sticking. common problem when cold. injs may be on the way out. the sct tunner may help.
Old 11-05-2012, 06:19 PM
I pulled some codes now :
P0683. Glow plug control module to pcm communication ckt
P2284 injector control pressure sensor ckt range/ performance
P0000 info not available
P2288. Injector control pressure too high
P2623. Injector control pressure regulator open
My guess now is icp sensor. Any suggestions!?
Old 11-05-2012, 06:24 PM
Can you read icp and ipr?
Old 11-05-2012, 06:29 PM
I don't know if you can.. Or how for that matter
Old 11-05-2012, 06:56 PM
Here......Write Up: Monitoring the 6.0L PSD.
Old 11-06-2012, 06:23 AM
The icp sensor is not the problem. There is no oil at all in it. I also unpluged the icp sensor and starte the truck. Still ran like crap for the first few minutes.
The truck will only start if its plugged in.
I think my next step is to test My gcpm
Or could it be my pcm?
My problems happend 5 mins after I took my edge off. Witch the edge hooked up to the pcm ( middle connected) and map sensor.
Old 11-06-2012, 06:42 AM
Hmmm, yea the pcm may have been corrupted. Can you hear all the injectors buzz when you turn the key on?
Tags
cold start, glow plugs, hot start
