turbo question help. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-04-2012, 08:19 PM Thread Starter
Question turbo question help.
I have searched but didn't find anything on it but. What should the stock boost pressure on a stock turbo be? Whats the MAX it can do.
Im wondering if when cleaning my turbo i might have put it back together wrong. IS that possible?
I thought before all the work i did, that i was getting higher pressures. Now the highest i have seen is 21psi. And my MPG is not as hight as it was. I am wondering could i have aligned the unison ring and actuator up incorrectly or if thats possible.
Any ideas would be great thanks.
04 Excursion 4in lift
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
Ficm repair with Atlas 40
CCV mod
BPD delete and water pump
need high idle mod soon
Pioneer DD head and 1k amp pushing two 12's and it was good.
averageguy is offline
post #2 of 8 Old 11-05-2012, 04:34 AM
southend's Avatar
I have seen up to 26 psi on my 04', may sure you do not have an exhaust leak.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 8 Old 11-05-2012, 06:33 AM Thread Starter
ive checked for leaks and I dont see nor smell any.
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
CCV mod
post #4 of 8 Old 11-05-2012, 06:35 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
my stock 6.0 could hit 27-28
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #5 of 8 Old 11-05-2012, 06:37 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 447 Post(s)
Garage
Doesn't the SCT tuner lower the boost #s a bit? I know the SRL does, not sure about the econo tune.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #6 of 8 Old 11-05-2012, 06:52 AM Thread Starter
I was seeing 28 or so before with the same tune im running now.
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
CCV mod
post #7 of 8 Old 11-05-2012, 09:59 AM
These are designed to put out atleast 28lb's from everything I have read.
This is the best write up I have seen for rebuilding your turbo. Maybe it could turn you onto something. It has lots of pics.
Rebuilding the 6.0 VGTurbo - Ford Truck Enthusiasts Forums
Leopold is offline
post #8 of 8 Old 11-05-2012, 06:34 PM Thread Starter
Good write up. But i haven't figured this out and I'm not happy with the way it is so i guess I'm going to take it back apart and check it again.
SCT X3 econ tune
Edge insight
Blue spring mod
4in MBRP SS no cat
Adrenaline Hpop
ARP's
CCV mod
