wondering - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-31-2012, 08:47 PM Thread Starter
wondering
Wondering if anybody else hase noticed coolant leaking in the "y" of the rear heater hoses on the back pasanger side of the motor? Looks like metal crimp bands holding hose on plastic y? wondering if just cut off crimps and add new y then band clamps, if anyone has had any luck with this methood. or just replace with new factor hoses?
FamExc is offline
post #2 of 6 Old 10-31-2012, 10:13 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
That will be fine,done it myself just make sure hose is not swelled up or damaged.
Srew hose clamps are the best way to secure the hoses.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 6 Old 11-01-2012, 07:55 PM Thread Starter
thank you did you use metal y of plastic?
FamExc is offline
post #4 of 6 Old 11-02-2012, 11:04 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Metal is going to hold up better but the new type of plastic they are using now is very durable and should hold up just fine. If your factory one is not damaged I would put it back on with no worries.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 6 Old 11-04-2012, 12:37 AM Thread Starter
factory y is no good having tough time finding replacement any ideas?
FamExc is offline
post #6 of 6 Old 11-04-2012, 11:28 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
If your handy with a torch I suppose you could make a Y out of copper, not sure where to find what truck has on it. Have you tried like a Napa store to see if they have anything? You may wind up at the dealer to get another one. But if your capable make your own,I would not use a straight tee, stick with the Y configuration for flow reasons. I'm guessing this is the Y below coolant tank?
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
