P0284 after replacing head gasket
I just finished replacing the driver side head gasket tonight. It started after about 20-30 seconds of cranking. Now idles rough and it threw a P0284 code. Could this just be because there's air in the oil system that needs to be worked out or do I need to start troubleshooting the #8 injector?
Truck ran perfect before swapping the head gasket. Would just pressurize coolant and puke out the cap. |
Check ficm harness plugs and injector harness plugs.
When i did mine i had the same problem, mine ended up being a bent push rod that killed the cylinder, once i replaced the bent push rod everything was good.
![]() Discovered the exhaust valve bridge wasn't set right. Berge Ford had both in stock. Replaced them and truck fired right up and now runs great. $35 in parts sure beats a new injector. Sent from my iPhone using Autoguide.com App |
