surging and sometimes wont start - Ford Powerstroke Diesel Forum
Old 10-20-2012, 06:57 PM
So this problem hasgotten worse over a month. It is almost like a defrost surge but has been getting really bad to the point sitting at a stop light it will lung u foward. And when it doesn't start it is random. I have done fuel filters cleaned the egr twice checked the ficm it was good replaced the air intake temp sensor. But have no ideas now.
Old 10-21-2012, 05:50 PM
Send a message via MSN to kmacicek Send a message via Yahoo to kmacicek
have you scanned it, does it have any codes that are showing up?
Old 10-21-2012, 07:41 PM
I have scanned it and nothing is coming up i even made it throw a code by disconnecting the icp sensor. Today I went thew the wiring harness that the icp.sensor goes into and found nothing I also blew out the connections to the computer and made sure it was good there
Old 10-23-2012, 05:58 PM
What year is your truck, how are you monitoring/pulling codes? Have no idea what a defrost surge is, but it sounds like a bad icp sensor.
Sent from my phone that somebody didn't help me get.
Old 10-23-2012, 07:43 PM
Its an 05 and. I have an edge. at an idle it kicks up anywhere from 50 to 100 rpms almost as if u started to let off the brake it takes off. I have played with the icp sensor and looked at the wires but did not see anything nobody can get the sensor for 3 days and its not cheap either and also hate to just throw parts at it.
Old 10-24-2012, 02:35 AM
Well if you have an edge, watch icp values to see if they are steady, or moving when it surges.
Old 10-24-2012, 05:34 AM
I will have to see if I can get it to monitor it thank u I will let u know what happens
Old 10-31-2012, 06:27 PM
I have the same problem with an 04. 58K miles. Had the icp replaced back in Aug. Ran great for about two weeks. Then went back to lurching. I removed the icp harness about three weeks ago. Haven't had a problem since. Not as responsive, but it's a work truck. Wondering if leaving it disconnected will do any long term damage??? Is sure runs good though...
Old 10-31-2012, 06:34 PM
It does not moitor the icp sensor but I had a shop look at it and they found the altinator was not outing out any volts I replaced it and have not had a problem yet knock on wood
