6.0 diesel operating limits - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-22-2007, 04:33 PM Thread Starter
I installed a edge perfromance module on 2006 F-250. I blew a head gasket about three days ago. I think I set some of the safety parameters to high on the module. I was wondering if someone knows or know how to get the operating limits for the engine such as max EGT,max turbo boost,max engine temp etc.
jet mech is offline
post #2 of 5 Old 10-22-2007, 04:49 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
I would keep it below 1400s EGTs for extended periods (short track bursts are OK, I hit 1440s), boost I would stay below 35lbs that way you should be safe, and the coolant you want below 220 if possible.
Also watch the tranny temps on hard runs or if you tow. Keep it below 210 I believe.
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #3 of 5 Old 10-23-2007, 04:57 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
I wouldn't get EGTs over 1200 if it were me. I have heard of people hitting 1500 for a split second but once you replace a melted turbo, you'll not do that again unless you have time and money to burn.
Boost....35 is pushing the limit in my mind...32 would be safer.
But then again i have an 03 and headbolts are more elastic on the 03s.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #4 of 5 Old 10-26-2007, 07:49 PM
william_04_x's Avatar
i've pulled grades in the middle of the hot summer and run 1250* pre-turbo for extended periods.. 30 psi for stock bolts on that motor is the high limit..
i've run with coolant temp at 236* when i'm pulling hard!!
04 EB X w/03 6.0l PSD
william_04_x is offline
post #5 of 5 Old 10-28-2007, 01:21 AM
white07psd's Avatar
Send a message via AIM to white07psd
1200? i can hit that stock. real chips dont defuel
2007 Ford f250 rclb
6.0l/torqshift
315/70r17 bfgs
FBD 4" straight pipe with 8" tip
skyjacker leveling kit
k&n fipk
looney tuned by dj :burnout
white07psd is offline
