i have a 04 6.o stroker, wont start.. changed lpop, icp, oil filter, checked all connections, good batteries, got fuel, got 48v koeo ficm, 47.8 volts when cranking, all 8 low circuit injector codes, ??/ got 9,000 kpa when cranking, is that enough oil psi?? some help me.. thanks
Your FICM is probably still bad. Voltage doesn't mean anything if it's not getting to the injectors and there's more than one way a FICM can fail
ok, so the ficm can still be bad even though voltage is right?, is there a way i can test it another way or check for issues before i spend the $$ for another one?
update.... low oil psi to icp...
