Removing passenger side oil rail. - Ford Powerstroke Diesel Forum
Old 10-09-2012, 05:43 PM
Question Removing passenger side oil rail.
I'm trying to take the passenger side oil rail off but the standpipe comes out with the rail and there's no room to pull the rail straight up. If I remove the hex bolt will the stand pipe stay in the head?
Old 10-09-2012, 06:12 PM
Powerstroke Techie
Feedback Score: 3 reviews
you are supposed to take the hex part out before unbolting the rail, you will need to start a few bolts back down to get it out, it is pretty tight (60ft/lb). it is the upper standpipe and the lower part should stay in the engine
sometimes the whole thing will come out when you unscrew the hex but it is 2 piece and can be seperated easily
Old 10-09-2012, 06:31 PM
Ok, gotcha. Thanks.
Old 10-10-2012, 07:42 PM
its like the same length as the other dummy plug just has a long tube on it, the tube can stay in the motor, to pull it out you have to seperate the plug the tube and you can pull the tube out very carefully!
Old 10-11-2012, 09:57 AM
Originally Posted by JaimeG View Post
Ok, gotcha. Thanks.
That is a really nice looking truck you have.
