not getting enough fuel to start - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-08-2012, 04:36 PM Thread Starter
i have a 05 f250, it wont start by just cranking the motor. i put a gas soaked rag over the air filter and it started and ran fine. reved it up and down and it never died ran just fine. when i turned the ignition off it wouldnt start back by itself. if anyone has any ideas or advice it would be greatly appreciated. thanks
str0kin is offline
post #2 of 15 Old 10-08-2012, 05:06 PM
6.0f250firstcar's Avatar
Can you hear the fuel pump start up when you turn the key to on?
6.0f250firstcar is offline
post #3 of 15 Old 10-08-2012, 05:19 PM Thread Starter
yea the fuel pump is working
str0kin is offline
post #4 of 15 Old 10-08-2012, 05:23 PM
Smoke out of exhaust while cranking?
post #5 of 15 Old 10-08-2012, 05:26 PM
Powerstroke Techie
justinmix's Avatar
More then likely a high pressure oil issue. A high pressure oil leak can cause a no start, depending on how bad the leak is. The high pressure oil system can't overcome the leak during normal cranking but when you use a "starting assist" of some sort it is enough to overcome the leak. If you're not familiar with these engines it can be kind of tricky to diagnose. I'd try checking codes first and see if you have any ICP related codes.
Does the oil pressure gauge move up when cranking?
justinmix is offline
post #6 of 15 Old 10-08-2012, 05:29 PM
Doesn't a HPOP leak usually affect warm starts?
post #7 of 15 Old 10-08-2012, 05:33 PM
Powerstroke Techie
justinmix's Avatar
Yes, they normally start out like that and get progressively worse but you can have a leak develop quick that will cause the same symptoms. Based off the symptoms it's my first guess but really need more info on it.
post #8 of 15 Old 10-08-2012, 06:00 PM Thread Starter
i havent paid any attention to the oil gauge while cranking. the only thing it ever done was it was taking a little longer to start than it usually did til finally it didnt start.
str0kin is offline
post #9 of 15 Old 10-08-2012, 06:06 PM
Powerstroke Techie
justinmix's Avatar
See what the oil gauge does. Just curious but still sounds like a high pressure oil issue. So this has been going on for awhile? Is it worse when it's warmed up? If so I'd guess at standpipe/dummy plug or STC fitting issues. Those are the most common failures usually.
post #10 of 15 Old 10-08-2012, 09:21 PM
southend's Avatar
I agree hpo leak.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
