dealer charge for head gasket replacement - Ford Powerstroke Diesel Forum
Old 10-07-2012, 03:49 PM
What should a dealer charge to replace head gaskets? Would they have any problem doing arp studs? Ive done egr valve and cooler removeable, bluespring mod that is it? What should I have them replace when they are that deep? Thanks.
Old 10-09-2012, 11:17 AM
jfg jfg is offline
Oil Cooler?
Old 10-10-2012, 02:38 PM
Where is the oil cooler located and what does it look like?
Old 10-10-2012, 02:49 PM
And how much is the dealer suppose to charge for changing head gaskets?
Old 10-10-2012, 03:08 PM
Powerstroke Techie
All depends on the labor rate of the shop. Expect to be charged about 22 or so hours for doing head gaskets.
For JUST head gaskets, with machine work on the heads, OEM head gaskets, rocker carrier gaskets, dummy plugs, and ARP studs I charge $3300. Now anything extra like an oil cooler/STC fitting/updated turbo feed and drain lines will add more to it but not a whole lot. Minus parts it should only be a couple extra hours tops for that stuff.
Old 10-10-2012, 06:59 PM
thats a good price justin. Im up in frederick alot visiting family. If i have a problem ill come your way! wheres your shop located?
Old 10-10-2012, 07:11 PM
Powerstroke Techie
We're actually just outside of Frederick in Woodsboro. Here's a link to the shop website.
http://www.xlr8dieseltrucks.com/pages.aspx?p=113223
I'm there Monday through Friday 8-5 every day. Feel free to stop by and shoot the breeze!
Old 10-12-2012, 05:23 PM
Thanks justin cya soon! Im up in harford county.. bout an hour and a half away from you
Old 10-13-2012, 04:50 AM
About the same price as a new focus.. Find somewhere else to take it..
