2004 F350 6.0 won't start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-04-2012, 09:23 AM Thread Starter
OK so I bought this truck used 2 months ago. has run well since until today. It won't start. can't smell fuel at exhaust as my 7.3 would have much unburned diesel in exhaust when it would not start. any starting point? Also a stramge vibration from a box behind the drivers headlight , a box with tubing coming out of the top.
minorproblem is offline
post #2 of 6 Old 10-04-2012, 10:22 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Is it a cold start issue or hot no start?
Do you have any scan tool?
One thing you can try with no tools ect is: unplug your ICP which is on the passenger valve cover, this will put the hpop system into default and if there is a problem there it should start. Also look into the plug assy for oil, if it has oil in the plug that's probably your problem and will need to replace it.
Obvious question here: are your batteries good and strong and is engine cranking over fast?
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 6 Old 10-04-2012, 10:25 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Only if his truck is a late build date 04, otherwise it would be under the turbo.
Also I agree you need to get a monitor on there to be able to provide more information about what's going on with the motor so we can better assist you.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 6 Old 10-04-2012, 10:29 AM
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Yea I saw the year was 04, was hoping odds were going to be in his favor.lol
If not on the valve cover he's not going to happy when he sees where it's at.......
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #5 of 6 Old 10-08-2012, 07:35 PM
gone6.0's Avatar
Quoted: 21 Post(s)
Thanks guys I have hooked up the Modis, no codes FICM cks good with 47.5v.
Truck still sitting,
The truck was running then started missing, the owner run the truck about 5 miles while it was missing, then shut the truck off and has never started again, hasn't even hit.
Sorry on the model year it is an 03, I guess i was thinking of mine. I havent really had time to check in with him on the truck lately. will check more tomorrow with the icp.
gone6.0 is offline
post #6 of 6 Old 06-26-2015, 07:08 AM
Question no start
I have a o4 f350 with the 6.0 I'm cant get it to start, when I turn ignition on to start all I hear is clicking in fuse panel, I had it towed last week and they disconnected the linkage from tranmission since the been having problems with it starting I would move shift shift arm and it would start now when I try nothing any ideas
bullrider69310 is offline
