rough idle this morning
So the truck has been fine. no real issues..... I get up this morning and there seems to be wet spot under the truck. smelled it....coolant. The truck started right up, no long crank or anything and the idle is rough. NO smoke, NO codes. I let the truck warm up to normal temp, and drove, seemed like a loss of power. turbo boosted up fine. it was almost as if a cylinder was missing. I don't have a monitor to do a cylinder contribution test, waiting on that. Could this be a FICM problem? would a bad injector cause this even if I get no smoke?
i'm just not sure where to start. i'm taking it to the place i bought it from because i have a warranty with them. But i want to make sure i know what i'm talking about. You know how the ealership mechanics can be....
Yes it could be your ficm, yes it could be an injector with no smoke.
Sent from my phone that somebody didn't help me get. |
ok so i just went back to start it up again and its fine. no coolant on the ground...
so i'm guessing this is a problem that only happens when it wants to. i'm still taking it in today to get everything checked out but still, this is strange. i'm guessing the FICM and the water pump need to be replaced. would a bad injector go in and out like that where it works fine and then goes out? from what i've read if there is stiction some revx might solve the problem. i'm going to grab some today to see if there is any dfference. but like i said it doesn't happen all the time. i'll have the FICM voltage tested today as well. i'll keep you guys posted.
Your money is best spent here.....Write Up: Monitoring the 6.0L PSD.
Rev-x will only help cold start rough idle condition. Could be ficm, injector, or icp/pigtail. Your truck will store codes. Sent from my phone that somebody didn't help me get. |
I have an injector that only acts up ocasianoly drives me crazy.
yeah thats what i think i'm dealing with. i'm here in Miami FL where its hot no matter what time of day it is. sometimes i cycle the engine 2-3 before starting in the mornings. just by habit i guess. do i need to do this or is once enough?
So just got back from the mechanic.....1 injector is fried and another is going out intermittently. Will be putting the truck in the shop tomorrow after work to get it done.
Sent from my SGH-T989 |
