Clutch fan ? - Ford Powerstroke Diesel Forum
Old 08-11-2012, 12:12 PM
Clutch fan ?
Hi to all
i need some advise and help on something
so the short story is that my f350 dually 2004 start puking some coolant from the degas
i have to say that i tow a gooseneck with an excavator on it
total weight whit the trailer is around 12000 pounds
i read and read a lot on the forum
seems i do not found my answer to make sure it is the good answer
i just change the cap yestherday but after reading some threads
i start to check the fan clutch
i can turn by hand when cold and turn by hand when hot
also when hot i stop the engine and i can see the fan still turning for a good 6 secons after ignition is off
please help
thanks
Old 08-11-2012, 12:14 PM
just want to add that my temp on gauge is not overheating or something like this
it is just when i tow
and i have big hill on my way back to home
thanks
Old 08-11-2012, 01:40 PM
Some actual temps would help us make a better diagnosis. The fact that u can turn it by hand is not a real indicater since you should be able to turn it but with some resistance. The fact that it free wheels for so long does indicate a possible weak clutch.
But like I said some actual temps would help.
Old 08-11-2012, 04:29 PM
ok ... lucky i am
one of my friend have auto eng . and we did a on demand test for fan high speed and it work perfectly
everyone with a 6.0 should have this
will make some more test
truck was iddling for at least 1 hour and the temp was around 180
i think everything is fine
and i think the big problem was the degas cap that i bought for only 10$
i will sleep better tonight
thanks for the help and for reading
