FICM issue
I seem to go through injectors like crazy!!!!!! Just had it in the shop a month ago for 6300 worth of work done, head gaskets, studs, oil cooler etc. got 3 injectors replaced at that time. Ran great for a while, seem to have another injector missing....AGAIN!!! Have replaced all 8 in the last 1.5 yrs or so. Now heres the kicker. I replaced the FICM just over a year ago with a used one. Never got the used one flashed, could this be causing my injector problems?!?!
You need a monitor, low battery voltage will kill ficms, you need to check you fuel pressure. Do you have the blue spring update?
Sent from my phone that somebody didn't help me get. |
Okay, I will check that. I am not sure if I have the blue spring or not, where is it located? is it easy to check/install?
| Tags |
| ficm, injector |
