ipr replacement question - Ford Powerstroke Diesel Forum
Old 08-09-2012, 05:33 PM
This is going to sound dumb, but I'm lost.
I finally got around to replacing the ipr valve on my 03 6.0l. I removed the degas bottle and the ficm to get access. I'm using an ipr socket to remove it.
The original one required a breaker bar to bust it loose. The solenoid does look like original equipment.
The new ipr screws in by hand no problem, but when it bottoms out the connector is pointing straight forward instead of up.
Am I doing something wrong? Do I really need to try and tighten it another 1/4 turn to get it to line up? I'm afraid of breaking something. Is it suppose to be that tight?
Thanks in advance
Old 08-09-2012, 05:55 PM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
The connector part can be spun to line up to the harness...at least mine did. I ran into the same issue when I did mine.
Old 08-09-2012, 05:57 PM
Thanks. I just saw that on the old one.
Old 08-09-2012, 05:58 PM
you shure you were given the right ipr. never ran into that before. a 05 ipr isn't intechangeable with an 03 if i rember right
Guess I was just lucky on all I changed and they lined up right when I installed them.
Old 08-09-2012, 06:23 PM
Powerstroke Techie
What he said.
