tow/haul won't disengage - Ford Powerstroke Diesel Forum
Old 08-08-2012, 10:18 AM
All was fine till the alternator went. Lost all gauges and lights. Started shifting hard, up and down. Tow/haul light started flashing. Pulled over, could smell that the alternator was cooked. Removed it and had it checked, zero output. Replaced with rebuilt all was fine. Hit approx 65kph tow/haul engaged, light started flashing, and won't disengage. Any solutions?
Old 08-08-2012, 10:23 AM
Have the tranny scanned see what is wrong. A tranny problem will cause the towhaul light to flash. You may need to get this done at a dealer not many aftermarket scanners can read all tranny codes or parremeters. Proprietary data.
