Low fuel pressure
Just like the subject says. I've got a '05 6.0 F250 CC 4x4 with 145000 on it. I have noticed in the last month that my fuel pressure is dropping. I've been religious on doing services on it, maybe a little OCD LOL. So when I seen it drop the first time I done a full service on it (3018 miles on new filters and oil before this service) but there was still np change.
I forgot to mention the normal fuel pressure was 55-60 and its now anywhere from 30-55 ( if its below 45 I shut it off and restart and 75% of the time it jumps back to 50) I replaced the HFCM about 10000 miles ago due to this problem and it helped some. It will also bounce from 35-65 lbs at cruising speed. I rebuilt the regulator when I changed the HFCM (blue spring). So tonight I done the BB mod with the blue spring and there was a 5 lbs gain but it still bounces around. I changed my pressure sending unit and made sure it wasn't getting too much vibration as well. Any help would be awesome. I've got to pull our boat (4300lbs loaded w/trailer) 300 miles on the 31st of this month. And don't want to start eating injectors. Thanks, Justin Sent from my SPH-D710 using AutoGuide.com App |
Wow no one has any advice on this?
Well it may be that some of us are trying to sort this out. You seem to be saying that you did 2 blue spring upgades, one on the filter and 1 in the. HFCM is this correct.
What are you reading the fuel pressure with and where? |
How are you monitoring fuel pressure? It may be a faulty sending unit, or you may have trash in your pickup tubes from a failed suction foot in your tank. Seen both happen.
Sent from my phone that somebody didn't help me get. |
Sent from my SPH-D710 using AutoGuide App |
First verify your guage is reading right. Second Dead head your pump and look at that reading(should be 65+). If all this is good put a vacuum guage on the pump inlet and it should draw at least 6" vacuum. If that is also good then I would look into the tank pick up. All this assumes your fuel filter is clean.
