hpop question - Ford Powerstroke Diesel Forum
Old 08-06-2012, 08:01 PM
hpop question
Just replaced my HPOP and Ipr valve ( valve on the HPOP)and truck wil not start . I cannot build any more than 8 psi of oil pressure . Then I took off the IPC valve(on the pass. valve cover) and the presure reading went to 1109psi . Once the IPC valve was plugged back in it went back to 8 psi .
As long as the IPC valve is un plugged I get pressure readings on my EDGE insight .Does this sound correct ?
Old 08-06-2012, 08:16 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Replace the ICP sensor.
Old 08-07-2012, 04:46 AM
If it is a bad icp, you can disconnect it and try to start it. If it starts, your icp/pigtail is bad.
Sent from my phone that somebody didn't help me get.
Old 08-07-2012, 05:19 AM
Feedback Score: 5 reviews
Read the IPR %...
Old 08-12-2012, 06:21 PM
what happen my is doing the same thing now
