i stumped a ford diesel tech maybe someone here can help!
well i bought the truck used with 112k on it and a reman motor. it ran great when i bought it and still runs well gets about 17.5 mpg i was thrilled with it. i started out on a 60-70 mile trailer pull pulling one horse in a little steel trailer after this winter putting an egr delete kit in from river city and doing the ficm fix. i made the trip there fine and let the truck sit over night and i noticed a baseball size puddle of oil under it and thats when i started noticing problems. after the trip home the leak got a little worse and started smelling oil on the exhaust. then one day i had to drive across the city to meet my girlfriend i left a gas station and got on it a little. the truck has an edge programmer on it nothing major and i run it on economy mode 95 percent of the time. well i got on it about 3/4 throttle for about 5-600 feet and i came up to a stop light and it was idleing at about 1000 rpm and while coasting to a stop it sounded like a 7.3 with a potentiometer. after coming to a complete stop it idled back down and then when accelerating from the light like a concerned 6.0 owner that realized somethings not right the throttle was like a light switch. on and off and while coasting it kept doing the choppy idle thing and staying at 1000 rpm. i have since changed the oil and it has quit doing it and i cant get it to do it which im happy about. but id still like to know what im looking forward to. hpop injector o rings injectors ipr valve what? o and the oil cooler gasket is leaking that is where the oil leak is but i plan on doing a top end gasket change soon. btw its a 04 built on 09/29 but i dont know what the engine is i dont know the interchangeability of the 03-04 and the 05-07 engines the reman was a long block but i dont know if it came with the injectors and hpop already installed. im not looking for a complete diagnosis just an idea of parts involved. i have posted on here before and have been fairly dissapointed with the results. i dont think one person responded last time. well thanks for your time and any sort of direction would be greatly appreciated.
Do you have any sort of gauges on the truck? Edge Insight, Scangauge, etc? If so are you throwing any codes? Assuming you do have a gauge check your deltas on ECT and EOT, also check your IPR pressure, it should be around 500-600 at idle and get close to 4000 at WOT. Also check your FICM voltage. Even if it was "fixed" doesn't mean it couldn't be a culprit. Also check ICP volts, should be around 0.2 to start and 0.8 when running. Get back to us with some more info and we'll try our best to help you out.
You say you stumped a Ford tech? Did he hook the truck up to Ford's IDS system and run tests on it? Seems strange that nothing showed up if the truck was hooked up to IDS? |
This is not a manned forum, sometimes no one is here and a post or 2 falls thru the cracks so to speak. Sorry that happened to you before.
As for now we would need a scan for codes and a live data scan and datalog would help. What you are describeing could be a number of things depending on the live datata readings. Without some detailed info I couldn't even make a wild guess. |
ok guys thanks for the quick reply i will have to see what i can do about getting live data reading its not throwing any codes and hasnt since i have had it. the tech that i talked to lives in another state he is a friend of mine and all i could do was describe symptoms to him.
oh and...
Is it still leaking oil? Have you checked your oil level again since that last oil change?
