Trucks not running too great on long trips up hills. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-05-2012, 02:36 PM Thread Starter
RoCkfiSh363's Avatar
So I just got back from crossing the Cascades and I can't stand how my truck shifts and runs. I'll be going up a hill and my truck won't downshift and my boost is real low and my EGT climbs really high to like 1100 if I don't pull my foot off it. If I put it in Tow/Haul it is a little better. It's almost like my Innovative tune isnt tuned too good. I have 38 inch swampers that are heavy. Should I get ahold of Innovative and see if they can correct this or should I be looking into 4.56 gears? Would that help alot? I'm running stock 3.73 as of now. Thanks for any help guys.
05 EX Cab Short
8 inch Fabtech
38 inch SSRs on 17x10 Centerlines(powdercoated)
SCT Innovative tunes
Banks CAI
Offroad MBRP Stainless 4.5 " and up pipe.
Auto Meter EGT, Fuel pressure, Trans Temp, Oil temp, water temp gauges.
Blue spring , bored 3 hole banjos.
ARP Studs
OEM Ford gaskets.
EGR Delete, cooler delete.
Bulletproof stand pipes
AMP Power Steps
Kicker Audio
Yukon 4.56 gears
Innovative 48v FICM Performance flash.
RoCkfiSh363 is offline
post #2 of 4 Old 08-08-2012, 02:20 PM
Same problem here... No ideas... I am getting a "boost leak" sound heard in the cab seeming to come from the area where the turbo is. Looked to see if I could notice a place where it could be leaking from, but no signs. :/
Geek'd Up Powerstroke is offline
post #3 of 4 Old 08-09-2012, 12:57 PM
I am having what seems to be the same problem. My boost will drop from 24-25 down to 6-7 psi in about 5-6 sec. I can barely reach the top of the hill. I also think I can hear a boost leak but can not find anything. Any help would be great. I have a Edge Evolution programmer set on tow mode, but the same problem happened before I put the programmer on.
onlyh-d is offline
post #4 of 4 Old 08-09-2012, 03:45 PM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
Have you checked your intercooler boots for rips or tears? How about the plastic CAC (intercooler) tube? It is prone to splitting. If you have checked all the boost side connections and haven't found anything, you have a problem on the exhaust side; which is either the up-pipe or the y-pipe. Both feed the exhaust from the manifolds into the turbo. Take a very strong flashlight (100 lumens) and look for soot on the firewall. If you have an exhaust leak in one of those two parts, you will have soot on the firewall.
See my post above. Same thing for you.
Yes, gearing would help out tremendously. Some folks (like me) haven't had good results with Innovative tuning. For whatever reason, my transmission doesn't like Eric's tunes and so I have tried several other tuners. For Daily Driving, I prefer the Looney tune from Vivian at Quick Tricks and for towing duty, I prefer the 8k tow tune from Matt at Gearhead.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
