'07 6.0 low injector control pressure when warm - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-05-2012, 06:31 AM Thread Starter
Myers129's Avatar
I have a 07 6.0 that won't start once it is warm anymore. At first start up I get about 700psi icp at 25% duty cycle on ipr. Once the truck is warm it only produces about 180psi at 85% duty cycle. The truck runs perfectly fine until you turn it off and then will not make enough pressure to pop the injectors. Is my hpop bad or is there something else that might cause this? Thanks guys.
2000 f550 crew cab 4x4 w/ utility bed
regulated return w/ bowl delete, 4" straight pipe, stage 1 single shots, DIY 6637, adrenaline HPOP, DP tuner F6= 80 econo, 140 aggressive, 140 extreme, towing tunes, 22.5's w/ super singles
Myers129 is offline
post #2 of 3 Old 08-05-2012, 09:51 AM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
High pressure oil leak. The snap-to-connect fitting on the back of the high pressure pump is a common cause. So are the oil rail dummy plug o-rings and sometimes even the standpipe o-rings get worn
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 3 Old 08-05-2012, 12:45 PM
southend's Avatar
Google 6.0 hpop leak test.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
