quick fix??? - Ford Powerstroke Diesel Forum
Old 08-05-2012, 06:22 AM
Exclamation quick fix???
Im getting egr valve codes and losing alittle antifreeze not in the oil. I just ordered the egr delete. BD Diesel 1090001 - BD Diesel EGR Delete Kits - Mobile SummitRacingEquipment.com that should take care of egr valve and cooler. I still have to gather the rest of the parts. But i have to still drive the truck. I thought about tacking egr valve closed or cleaning it good and unplugging it and removing thermostate. Any suggestions?
Old 08-05-2012, 06:55 AM
you'll still get the codes of course if you unplug it ,, but try just cleaning it and plugging it back in
I wouldn't pull the tstat the system will still have the same PSI in the coolant system ,,
on a 6.0 it can be deceiving on coolant loss because the Degas bottle has a level that varies due to different conditions throughout the day ,, so are you actually having to add ? if so how much
since you don't have any true signs of a bigger problem I would drive it myself
but I won't recommend that to anyone else ,, know what I mean ?
Old 08-05-2012, 06:58 AM
are you getting a tuner with the delete to bypass the CEL that will set off ?
also save that valve you may need to plug it in and zip tie it to the firewall to avoid cooling fan issues
Old 08-05-2012, 10:27 AM
Yeah later im getting the sct sf3. To keep the codes gone. But would it be be safe if the valve was stuck closed then maybe hanging open
Old 08-06-2012, 08:37 AM
when you clean the EGR force it open with your fingers .. you can tell if it wants to hang open
