6.0 blows raw fuel - Ford Powerstroke Diesel Forum
Old 08-05-2012, 05:35 AM
6.0 blows raw fuel
my truck lost power and quit now it will start sometimes but smokes and smells like raw fuel...fuel is also coming out behind the turbo out of the down pipe any ideas where to start..has egr delete
Old 08-05-2012, 06:24 AM
Put a scanner on it and do a cylinder contribution test. If one shows a fault at least you know where to start. Does your boost gauge read any higher than normal?
Old 08-05-2012, 06:44 AM
boost is fine...truck ran great then wham pissed up...
Old 08-05-2012, 06:46 AM
won't stay running long enough to do test..runs for a bit and smokes bad fuel smoke...then dies out about a minute later
Ok just curious cuz mine bent a pushrod coming onto the highway once and it made the truck run like chit and was about 25psi at 60.
