CRANK NO START ! ! ! ! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-02-2012, 02:12 PM Thread Starter
FritzLabrenz's Avatar
Big problem here, at my ends ! ! ! ! Give you guys a little back story. Have a 2005 F350 6.0. Guys motor threw a rod . . . So we got a junkyard motor and slammed it in. At the same time put in updated head gaskets and bolts from FORD. New filters fuel and oil. . . Truck goes 2 weeks and comes back rough running. After diag found low voltage at FICM (32 volts). Took FICM apart and found the resistor soldier cracked. Resoldiered all of them and also other common problem soldier joints. Reinstalled and truck ran GREAT (solid 48 volts). Well . . . About 6 months later truck comes in running fine but popping back through intake. Found 2 bent pushrods and 1 roller liffter blown up. I replaced broken lifter and F*d up camshaft. Checked all other lifters, OK. Put motor back together, ran truck for 2 days and about 50 miles. Truck ran great ! ! ! I gave the truck back to the guy and idleing there starts to misfire and run like crap ! ! ! ! I hook up scanner and have balance codes for cyl 1 & 2 (P0263 & P0266). So i did an electrical test on injectors . . . All injectors test out okay (0.3-0.4 ohms). I leave truck for the morning . . . Truck doesnt want to start now ?!?! Check voltage at FICM (48 volts) (12.5 volts second screw) ICP is at 1127 psi demand matches actual. IPR is at 40%, 55 at first crank but goes down to 40. Had a spare GPCM so through that in, still nothing. Checked the usual rub through spots on harness . . . nothing, i think this has updated harness cause every suppect place has extra insulation. ICP sensor is also brand new. Scanner says cam and crank SYNC is OK . . .out of ideas !?!?!?!? PLEASE HELP ! ! ! !
FritzLabrenz is offline
post #2 of 12 Old 08-02-2012, 07:23 PM
southend's Avatar
I'm thinking your ficm repair was a temporary repair, logic board took a crap.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 12 Old 08-02-2012, 07:32 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
^^ that's be my guess too
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 12 Old 08-02-2012, 08:53 PM Thread Starter
I was thinking the same . . . I was wondering if there was any way of testing the board or is it pretty much throw one in ??
post #5 of 12 Old 08-02-2012, 08:57 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
I think you have to test the voltage?? I'm not 100% on that but I think thats what you do to see if it crapped out on you. I think that the voltage on the logic board should be around 14v I can't remember.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #6 of 12 Old 08-07-2012, 09:44 AM Thread Starter
well put another FICM in and still nada . . . Only thing i can tell is my injectors click slow on key on. I remember that the click very fast orignally and now it's like 1 click a second . . . I have no clue
post #7 of 12 Old 08-07-2012, 10:13 AM
southend's Avatar
Does that mean you got a new ficm?
Sent from my phone that somebody didn't help me get.
southend is offline
post #8 of 12 Old 08-07-2012, 11:08 AM
What is your battery input voltage to FICM 12v min. I have seen low voltage to cause some freaky FICM responses.
Have it scanned on live data while cranking. Look at all FICM voltages in and out. Check for sync both FICM and PCM, Check all crank run pids for good measure. ICP actual and desired Fuel pressure etc. You need to see what the PCM is seeing.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #9 of 12 Old 08-07-2012, 03:57 PM Thread Starter
input to FICM 12.5, Have battery charger on it. Plus i put 2 new batteries for good measure. I got a FICM from a running truck. Didnt want to spend alot of $$$$ on a guess. Still exact same thing, crank no start. All pids and sync look good. At least on the Snap On scanner they say okay. I put starting fluid in and it lights up for a quick second.ICP actual and desired still match up at between 1100 - 1200 (varys on cranking). Got a Ford diesel tech comming to look at it for $80.00 tomorrow morning so we'll see what he has to say. Keep you guys posted. I'm thinking a bad ground or something in harness . . . Slow injector click is pointing me that way . . . we'll see
post #10 of 12 Old 08-08-2012, 08:16 PM
WDCDAVE's Avatar
any luck on this ?Got identical issuse almost my icp are at 980 and my ficm sync reads 1
Made to be drivin hard.This is how I decided to stick with the 04-06 6.0
06 F-350 Lariat 4 in on 35s eagle eyes 248 k
06 Lariat Dually 367 k
05 XLT Super-cab fancy paint and 20 in rims 145k
05 XLT Dually kinda stock but have plans 288 km
99 F250 7.3 just a cool truck 185 k sold
09 F-150 King Ranch The cruiser
06 F-350 XLT 178 km
06 F-350 XL Super-cab 147km
01 F-350 XLT Deck Truck 06 front clip 288 KM 7.3
2010 F-350 Dually slightly modded bought at 58,000 pushing 259k
WDCDAVE is offline
