Long crank when cold but start fine after that - Ford Powerstroke Diesel Forum
Old 08-02-2012, 08:05 AM
I have a 06 ford f250 with a 6.0 the new version. I have had the truck for a year it has been doing this the hole time could it be sticky injectors or do I need to take to the dealer and have them check it I have no check engine light on or nothing but sems to run find after it starts. I don't sit there and lay on the starter tell it starts I crank for a few seconds then cycle the switch and repeat. I only have to do this twice then it fire up. But after it warm up it fine it fires right up just when it is cold
Old 08-02-2012, 09:41 AM
Mine was doing the same thing, except mine would start for a second and die. I had to replace the ICP sensor
Old 08-02-2012, 10:19 AM
What is the icp sensor and what is it function
Old 08-03-2012, 04:58 AM
the icp is the Injection control pressure sensor. It gives feedback and tells when to fire the injectors
Old 08-03-2012, 06:43 AM
This is correct. If the ICP does not show a 500psi HP oil pressure reading to the PCM, the PCM will not command the FICM to fire the injector sequence.
Old 08-03-2012, 07:03 AM
Make sure you have motorcraft filters and caps.
Sent from my SCH-I500
Old 08-06-2012, 11:35 AM
Okay I just did my oil change I have all motor raft filters in fuel and oil both I also have vavaline blue in know 15/40 we will see if there is a change. I will let u all know wensday morning for sure
Old 08-06-2012, 12:02 PM
Got another question there is a pretty long delay from ideal to wide open would that be a symptom of the icp going bad
Old 08-06-2012, 12:11 PM
If you mean acceleration, I would think sticking turbo vanes.
Sent from my phone that somebody didn't help me get.
Old 08-06-2012, 02:12 PM
Yea from a dead stop it seams to be a small delay from ideal to wot. And it seam to take it alittle while when driving it. I notic all of this while driving but just seating at home in drive way it fine. Maybe I should just take it to a dealer and have them scans and see what they say
