6.0L problems! need some help please! - Ford Powerstroke Diesel Forum
Old 08-01-2012, 04:57 AM
My stock 2003 6.0 started hesitating a few weeks ago after towing a car and trailer (about 5,000lbs). Then it had a long crank time that eventually turned into a no start. Checked FICM and it was bad, 38V. Swapped it out with one that was from an 06 with a rebuild on it. Dealership did the flash on it and now it blows a lot of white smoke at idle and A LOT of black smoke when driving. Even if I'm slowly accelerating. Sometimes it will idle rough, sometimes its fine. I have plenty of power, turbo spools up fine. Been about 200 mi since I changed the oil, put in a new egr valve, I'm not losing coolant. No tunes, eot/ect delta is from 5-8 deg at all times. New radiator, only thing after market is the muffler. I have about 116,5xx miles on it. Sorry for being long winded I just need to get it fixed so my wife and I can take our trip to flaming gorge, Ut and tow our boat. So any help is appreciated!!!!
Old 08-01-2012, 05:30 PM
Edit: new motorcraft fuel filters too.
Old 08-01-2012, 05:59 PM
You need a monitor to pull codes. Sounds like overfueling.
Sent from my SCH-I500
Old 08-01-2012, 07:13 PM
Hopefully you have oem caps with those filters?
Old 08-02-2012, 02:40 PM
Why does it matter what type of filter it is all filters do is filter and clean the oil and fuel and air. Please explain
Old 08-02-2012, 02:56 PM
Here you go, read the top, watch the video.......make your decision. http://www.dieselfiltersonline.com/f...k-filters.aspx
Old 08-02-2012, 03:01 PM
Here is more from alliant......http://alliantpower.com/6liter-technical-bulletins
Old 08-02-2012, 03:26 PM
I ran rotela in my 7.3 and frame filters in it for years and never had a problem been running rotela in my 6.0 with all the spec they requir to be in the oil and frame oil filter and never had a problem so I don't know jmo I guess thank for the info tho guys
Old 08-02-2012, 03:31 PM
Also here in my ford maintenance and specufication book it says motorcarft of oil conforming to ford specification it up to u guys jmo
Old 08-02-2012, 03:41 PM
Yea, I have a 7.3 with 309k on it, I use rotella and a motorcraft on that because I can get it from walmart, it is obviously not a cartridge type filter. So the concerns with the cartridge type filter do not apply to the 7.3. But I see you are having starting problems on your truck, maybe you should consider using the oem cap and motorcraft or racor filters. And noone is disputing the use of rotella?
