'05 6.0 Stopped Mid-Stride
Over the weekend, fixing the no start when hot issue, replaced STC fitting and dummy plugs. While in there I deleted EGR. Truck ran great for next 2 days.
Last night, approaching a stop sign, she just stopped running. Motor turns over but no start all over again. Any ideas?
Check the fuel reset button. Its under the dash on the passenger side.
If that doesn't fix the problem, check your Battery voltage, then your FICM voltage.
Tried that. Still nothing. Is it possible the STC I installed could have failed already?
Did you get the updated stc fitting? If so can you measure ICP
What was your ficm voltage during starting?
reset fuel button, has 2 new batteries, new icp,new upgraded stc fitting, installed egr delete, new straight pipe exhaust, new air intake. still just cranks, no start. gotta check for fuel and test ficm. what else other than a stick of dynamite?
When you turn the key to run, can you hear the fuel pump run?
yes, fuel pump runs.
2 new dummy plugs also
| Tags |
| 6.0, no start, shutdown, stc, sudden |
