Cleaning injectors - Ford Powerstroke Diesel Forum
Old 07-30-2012, 01:02 PM
Cleaning injectors
What's a good way to clean the injectors, I just replaced my #7 on my 03 6.0 and there were only 2 holes on the nozzle that were open so I'm sure the others are going to get that way. So what's some possibilities on additives to try!! Alittle advice on this would be great!! After the injecter was swapped the truck runs so smooth FYI
Old 07-30-2012, 01:25 PM
Hot Shot Secret or Revex!
Old 07-30-2012, 01:27 PM
Ill be interested to know as well....will revex really help that much??
Old 07-30-2012, 01:36 PM
I've never used Revex but I do run Hot Shot Secret and it does make a huge difference!
Old 07-30-2012, 01:37 PM
I have heard a lot of good things about Revex though.
Old 07-30-2012, 02:59 PM
We're can I find that hot shot stuff!!
Old 08-05-2012, 01:28 PM
RevX is for the oil side of the injectors, not the fuel side.
Old 08-05-2012, 01:40 PM
This is correct. RevX is an oil additive that helps with striction issues of the solenoid valves on the injectors.
While I am not a big fan of mechanic-in-a can products just be shure the product is made for diesels. You really do not want to use a product made for gas engines, you can blow the tip right off the injector. They are too volital and can cause serious cylinder/piston damage.
