6.0l no boost
new to the forum. have a 2005 f250 superduty with the following:
-egr update -ficm update -stc fitting replaced -new egr -66k miles -oil changed every 3-4k -sct tsx performance tune was running fine down the highway today at about 50mph barely on the throttle. went to pass and pushed down on the accelerator pedal about 1/4 throttle and it felt like the engine popped/hicupped and then no boost. pulled over and checked CAC boots but everything appeared okay. limped vehicle home and noticed different colors of smoke (dark and light; sorry, i'm a little colorblind) when i pushed on the accelerator; more smoke with more throttle. check engine light has not come on. pulled out the egr but it looked very good. i'm thinking a turbo issue but with the low miles not sure. also, hoping the suddenness of the problem may be a sign of something. any help would be appreciated. also checked map sensor hose but it looked okay. jeff Reply With Quote |
exhaust flex joint cracked, cac boots(they are hard to inspect in the truck), cracked cac. Imo
Sent from my SCH-I500 |
problem found
turbo impeller shaft snapped in the exhaust side. just for grins the broken piece augered itself into the downpipe. disappointing....... much thanks for the advice.
jeff |
Sent from my phone that somebody didn't help me get. |
