Bad injectors? - Ford Powerstroke Diesel Forum
Old 07-25-2012, 02:56 AM
Bad injectors?
The dealer told me I need 2 injectors. I did a resistance test and came up with .7-.9 ohms on all 16 coils. Is there another way for injectors to fail electronically?
Old 07-25-2012, 08:37 AM
Maybe indirectly, check this out...........Why you shouldn't drive around with injector codes! .4-.6 ohm at ambient is normal. What made you get this checked out? Symtoms? Codes.
Sent from my SCH-I500
Old 07-25-2012, 10:53 AM
I read that a couple days ago. The engine was still warm when I checked them yesterday. I also read somewhere else that .8 is normal. Read my other thread called "crank but no start" I have all the problems listed in there.
Old 07-25-2012, 12:04 PM
Ok, well your numbers are probably ok. But if in fact you also have a screw that fell out, your coil could not move the spool valve. You may need to pull the valve covers.
Old 07-25-2012, 02:47 PM
Ya I gotta at least pull the driver side off cause I pushed the plug inside when I went to plug the harness back in. I'd be working on it right now but I have community service lol
Old 07-25-2012, 02:58 PM
Geeez..... lol, well thanks for your service to the community. Lol
