trucks just ate its 2nd new injector any suggestions? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-22-2012, 06:43 PM Thread Starter
fatheadon1's Avatar
Hello guys i just got done doing a top end up refresh on my 05 6.0. while apart i sent my working injectors to warrens diesel to be gone threw an bumped to stock plus size. Now the truck is back together i fired it and got a rough idle an code p0284. So i called warren, shock that an injector had failed but they still next dayed an injector to me. i get the injector installed fire it up truck idles great, take it for a spin an the truck seams ok till the first time i got into it, i got a cloud of black smoke and now have rough idle an code p0278cyl #6 contriution/balance same code as before but now but different cyl#. Any suggestions?
the truck has had the blue spring in it for about 1500 miles the ficm was just at ficm repair and got a super clean bill of health from ed. fresah oil oil filters and fuel filters. i really dont have the heart to call Jessie at warren an tell him this bad news as hes been a stand up guy from day one but i am stumped. HELP ME PLEASE?
2012 f350 ccsb diesel 3.55 eld fx4 9'6mvp hids 20'Ridge led bar ,325/60/20 duratracks, train horns,titan 50gal, sd truck 2.5 front springs,carli 6 pack rear,recon smoked ,tail,mirror,cab lights, B.F.C projector retrofit,titan 50gal, Whelen lin6,vertex strobes and SoundOff 1400 Lumen back up lights, , 05 f250 ccsb diesel, harley wheels 285/65/20 bfg A/t studded egr del MTW stage 2 warrens 155/stock sct xcal3,scangauge,add a leaf,Wide-OUT, Tornado 1.7 same strobes an back up lights as th 2012
fatheadon1 is offline
post #2 of 4 Old 07-23-2012, 04:39 AM
southend's Avatar
Ficm harness? Check your plugs also.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 4 Old 07-23-2012, 05:01 AM Thread Starter
fatheadon1's Avatar
I got a solid CLIcK out of the plugs when they went in. How do I test the harness?
post #4 of 4 Old 07-23-2012, 05:04 AM
southend's Avatar
Wiggle it while it's running, no real good way of doing it unfortunately. Best to check real close for chaffing.
southend is offline
