Degas bottle?? - Ford Powerstroke Diesel Forum
Old 07-21-2012, 05:51 PM
Degas bottle??
My degas bottle was just about empty about 2weeks ago so I added some distilled water to the mark(lower mark than factory) took off for a 3hr. Drive and it blew it out. Truck is studded,deleted, not running hot. And degas bottle still empty when motor is warm. I have driven roughly 1500 miles since then truck is running fine even pulling 8k camper. Any thoughts thanks
Old 07-21-2012, 05:54 PM
Black onyx gaskets? Were the heads decked?
Sent from my SCH-I500
Old 07-21-2012, 05:56 PM
Yesr to both. I've got 14k on them
Old 07-21-2012, 05:59 PM
But it's not puking.
Old 07-21-2012, 06:03 PM
Put some more coolant in there, it will puke and burn it down the pipe. So where do you think it's going?
Old 07-21-2012, 06:06 PM
Lol it's coming out the cap. Replaced cap when studded it. Reason I said its not puking its not making that dreadful sound. And is running like a top!
Old 07-21-2012, 06:14 PM
Mine did that same thing and I'm in the middle of a head gasket job right now. It's literally sucking coolant in small doses. Even not running wacky or puking it's 100% possible to have a blown head gaskets. It sucks it in and turns it to steam but it's not sucking enough to cause white smoke.its unfortunate but welcome I the world of owning a 6.0. Mine is studded and has an egr delete. Black onyx gaskets.
Old 07-21-2012, 06:17 PM
Well that sucks! How did u find out it was head gaskets?
Black onyx gaskets, bad head job, losing coolant = blown head gaskets/cracked heads/damaged injector cups. Unless you have coolant leaking on the ground.
Old 07-21-2012, 06:20 PM
throw a pressure gauge in the coolant circuit and check it out
also ford recommended to Me a cap and bottle replacement because of sealing issues
Mine was still head gaskets
