My BLUE SPRING Update! - Ford Powerstroke Diesel Forum
Old 07-21-2012, 03:40 PM
Installed my Blue Spring update and thought I would post some pictures. If anyone has not done this I would highly recommend it. My 6.0 has a little more pep in it's step now!
Step 1: Using a set of chanel locks remove the 3/8" hose coming off of the top of the degas bottle.
Step 2: Remove the intake pipe using 13mm deep socket
Step 3: Remove upper radiator hose or just tie/pull it down (this is what I did)
Step 4: Remove the secondary fuel reservoir cap using a 1/2" drive and then remove the return fuel line using a 7/8" and 13/16" wrench then remove the 4 screws holding the cover plate on using a T27 bit.
Step 5: Remove the old components and install the new ones. Remember to oil all O-Rings (I used T6 on mine).
My BLUE SPRING Update!-step-1.jpg   My BLUE SPRING Update!-step-1-remove-intake-pipe.jpg   My BLUE SPRING Update!-step-2-remove-uper-radiator-hose-tie-down.jpg   My BLUE SPRING Update!-step-3-remove-fule-return-line-using-7-8-13-16-wrench-then-4-regulator-screws-.jpg   My BLUE SPRING Update!-step-4-install-new-blue-spring-other-components.jpg
Old 07-21-2012, 03:50 PM
Step 6: After oiling the cover plate O-Ring use your thumb to press in and hold cover plate. Then use T27 bit to reattach the 4 retaining screws. Then use the 7/8" and 13/16" wrench to reattach the return line. Reinsert fuel filter and use a 1/2" drive to tighten down fuel filter cap.
Step 7: Reinstall radiator hose, intake pipe and degas hose then test drive it. You will be able to tell the difference! I hope maybe this helped someone. Total install time was about 30 minutes and total cost was $60.00
My BLUE SPRING Update!-step-5-install-regulator-plate-cover-reconnect-fuel-return-line.jpg
Old 07-21-2012, 04:21 PM
Little more than i care to do on my own since i have a van...
Old 07-21-2012, 04:48 PM
Great write-up, dude!!
Old 07-21-2012, 04:54 PM
Thanks man. How is the rebuild going? I want to do an EGR delete and studs next.
Old 07-21-2012, 04:59 PM
it's going ... SLOW.
LOL
Actually, I expected it to take time. Luckily, I have a take-home car from work, so I don't really NEED my truck right away.
Pulling it apart, we looked at the cross-harching in the cylindars, tested the injectors, a whole bunch of stuff...everything looks pretty good. It should be good for another 300,000 miles when it's finished (...might need injectors or a TC or trans, but the motor should be tight...)
I cant wait to get it back!!
Old 07-21-2012, 05:05 PM
Man that sounds great. Like you I'm so glad I have a take home car. When my truck is down its nice to not have to worry about a ride to work. I'm hoping when I bullet proof mine it will be the last time and the last truck I ever own. Do you know ant Stauffers in Mechanicsville, MD?
Old 07-21-2012, 05:22 PM
Great info, if I could add, I saw no reason to remove the filter, and I put a dab of anti-seize on the screws before i re-assembled. :thumbup:
Sent from my SCH-I500
Old 07-21-2012, 06:37 PM
Deer Creek - There is a Stauffer's Feed Mill just south of Mechanicsville in a town called Loveville. It is owned by an Amish family. The Stauffers around here almost all Amish. I don't know too many of them ... I know quite a few Amish from the Swarey and Stoltzfus families though.
Why do you ask?
Old 07-21-2012, 06:44 PM
Thanks for the pics, I think Im gonna try this for myself...
