Need help getting belt back on alternator after egr delete! - Ford Powerstroke Diesel Forum
Old 07-14-2012, 04:39 PM
So I can't figure it out. Is there a trick. When I unbolted it I leaned it forwar then took the belt off and sat it aside. Now trying to mount it back and I tried leaning it back with belt and I just don't have enough *** to hold it down and get bolts in/ line up. Help please. Need advice
Old 07-14-2012, 04:43 PM
Lock the belt tensioner and just do it the proper way, these belts are to strong to do it the other way and you run the risk of damaging something. A 1/2 in breaker bar or ratchet with a cheater pipe will do the trick.
Old 07-14-2012, 05:42 PM
I just went to the auto parts store and rented the proper tool for 5 bucks. It worked great.
Old 07-14-2012, 05:45 PM
Feedback Score: 3 reviews
I always use a long 1/2" ratchet and cheater bar like mentioned above; always works great!
Old 07-14-2012, 05:59 PM
I use my arm and pull the belt , lock the tensioner =Free
Old 07-14-2012, 06:00 PM
You must be a giant! Those belts are tightttttt.....
Or maybe I should just be working out more
Old 07-14-2012, 06:12 PM
lol
IDK I am 6'4" and 240 so maybe being a fat Arse paid off for once
Old 07-14-2012, 06:44 PM
Powerstroke Techie
I do the same thing. But I have found that the 05 and newer 6.0's use a stiffer tensioner. I used to grab the belt with 2 hands and pull up and slip it over the alternator pulley. But then I discovered the lock on the tensioner.
Old 07-14-2012, 07:33 PM
Thanks guys. I tried pullin it. I'm 6,2 200 pounds and it's not happening lol. I'll try the tensioner lock. Wheres It located?
Old 07-15-2012, 05:25 AM
On the tensioner...........i believe it's in the owners manual.
Sent from my SCH-I500
