Head gasket replacment questions - Ford Powerstroke Diesel Forum
Old 07-12-2012, 03:34 PM
I just recived my heads back from the machine shop and gathering everthing together to put the heads back on .
A few questions have come up so far while revewing my gaskets and processes for the rebuild .
1) When I removed the exaust manofolds there were no gaskets in place . The gasket kit that I purchased had them in the box . Should I use the gaskets or install with out them like they came apart .
2) When I install the valve train does there need to be anything done to the crank position . The motor has not been turned over since they were removed.
If there is anything special I need to look out for during install please let me know .
Old 07-12-2012, 05:19 PM
Bump for ya.
Sent from my DROID X2 using AutoGuide.Com Free App
Old 07-12-2012, 05:32 PM
Most would say install the gaskets, the crank dowel needs to be at the six o clock position.
Sent from my SCH-I500
Old 07-12-2012, 05:51 PM
Thanks for the input ..
Old 07-12-2012, 07:55 PM
I've been curious about this too. just need to put the crank at 6 o clock, and nothing else? Just reassemble? Wanna get this right for when I do mine in about 2 months.
Old 07-12-2012, 08:30 PM
Not sure the reasoning behind it .I will let you know how it goes . Alot of money invested so far just want to get it right .
Old 07-12-2012, 09:56 PM
Just did my 2005 man. In the cab in my garage. It's pretty fun huh? The dowel needs to be at 6 because it makes sure your piston tops won't come into contact with your valves when you tighten back down your heads. I didn't do this but I may have gotten lucky. I didn't use any manifold gaskets but I thought long and hard about it. I just cleaned the surfaces up with a red scuff. While you're doing it all you should also do upgraded banjo bolts, and I'm not sure if the 04 is the same as the 05 but I also did bullet proof oil stand pipes on the rails. P.S. when it comes time to fire her up. Be patient and have some battery chargers handy. It took me 2 days of off and on cranking and charging before she fired.
Old 07-16-2012, 08:53 AM
To the op, did it work out for you. Putting crank at 6 o clock work?
Old 08-10-2012, 05:42 PM
Bump to top.
Old 08-10-2012, 06:57 PM
FYI, the manifolds are originally installed with no gaskets. However, you're supposed to install gaskets if you ever remove the manifold.
