Cooler or Gaskets - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2012, 08:28 AM Thread Starter
Cooler or Gaskets
Ok so I'm loosing coolant and can smell it through my air vents when I raise the RPM's. No pooling under the truck, but there is sign of it coming out of the filler tank (chalky residue). My plans are to change out the oil cooler with a sinister and also do an EGR delete. What are the chances that I will also have a gasket problem? Am I heading down the right track for this problem, or do I need to do more? Also going to go ahead and modify the exhaust to MBRP 4" turbo-back, S&B intake and an H&S Mini Maxx. Am I spending all this money wisely??
dhooper is offline
post #2 of 7 Old 07-11-2012, 08:36 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Be a great time to do the hg's if your puking coolant you most likely have Blown hg's. Stud it with OEM gaskets and do all the updated parts replacements. Stand pipes dummy plugs blue spring kit 6.4 banjo bolts turbo oil drain and feed tubes ccv mod stc fitting etc. It'd be ashame to rip it down that far to do the oil cooler and not go a little bit further and swap studs and gaskets, then put it back together only to have to rip it down again only further this time to do it right. Jmo.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 7 Old 07-11-2012, 08:43 AM Thread Starter
Yeah thats what I was wondering, but don't you have to pull the motor to do the gaskets and studs?
dhooper is offline
post #4 of 7 Old 07-11-2012, 09:01 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
No you don't even have to pull the cab. I'm getting ready to do mine here shortly just getting the rest of the money and parts together for the build. I'll be doing it in my driveway cab on. It will take some time to get it done so don't expect to have it done over a weekend unless you do this for a living. Lol plan on about 1-3 weeks to get it done depending on your schedule and how often you plan on working on it.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 7 Old 07-11-2012, 10:03 AM Thread Starter
Good deal, I'm going to talk to the mechanic about this. He drives a 6.0L and has already done all these modifications to his in the past. Thanks,
dhooper is offline
post #6 of 7 Old 07-11-2012, 02:20 PM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
It's pretty tough to properly torque head studs with the engine in the truck. I get calls from guys all the time who've put the ARP studs in thinking that they were doing some preventive repairs only to have a head gasket blow at some time afterward. Also, if you are putting ARP Studs in, make sure that you follow ARP's torquing procedure not Ford's.
AshevilleEngine.com is offline
post #7 of 7 Old 07-11-2012, 02:25 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
its not difficult if you use the torque adapter tool made specifically for the 6.0l to get in the tough to reach spots. also the torque proceedure is the same as fords only difference is that you put studs in hand tight then use the fasteners and torque down 3 separate times 70, 140, and finally 210 ft pounds in the same torque sequence as ford says to torque the studs. pretty cut and dry its just a pain to pull and lower the heads by yourself is all.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
