04 6.0 Very hard to start after sitting over 3 hours - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-10-2012, 08:25 AM Thread Starter
Belt Fed
HHB Guns's Avatar
Truck has been running like a dream since I replaced all the injectors first week of march. Drove fine yesterday morning and came home around 11 and parked it. Had to run uptown at 2:30 and got in and cranked it over about 5 seconds and nothing. Turned it off and back on two more times for 5 seconds and on the third time it started up and it runs like a dream. Went where I needed to go and cut it off and was in the store for about 20 min and it started right up. Came home and parked it until last night about 6 hours later and it did the same thing.
Oil change is at 4700 miles and soon to be changed, current fuel filters are at 4700 miles as well. Batteries are new as of Feb.
I really have no clue where to start....Should I just start with a new filters and oil or am I totally off Q?
Henry H. Bryant
AKA: Beau
HHB Guns, LLC
FFL 01/ Class 3 SOT
2004 F250 Lariat FX4
10" Superlift
40" Interco SS-M16
24" Dubs
BushWacker Fender Flares
Bully Dog Cold Air
EGR Delete
MBRP Exhaust
Head Studs..LOL..Was told yes but not 100% for certain!!
HHB Guns is offline
post #2 of 8 Old 07-10-2012, 08:40 AM
southend's Avatar
I'm guessing you dont have a monitor....(sigh)
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #3 of 8 Old 07-10-2012, 10:37 AM Thread Starter
Belt Fed
HHB Guns's Avatar
No....(Sigh)
Its been on my buy list but every time I get the money saved up to buy one Life happens and money has to go elsewhere.
I do however have a bluetooth OBD reader and have "torque" app on my phone. Is there a particular guage I should be looking for that will help me diagnose.
Henry H. Bryant
AKA: Beau
HHB Guns, LLC
FFL 01/ Class 3 SOT
10" Superlift
40" Interco SS-M16
24" Dubs
Bully Dog Cold Air
EGR Delete
MBRP Exhaust
HHB Guns is offline
post #4 of 8 Old 07-10-2012, 11:02 AM
southend's Avatar
Dtc's will help.....ficm voltage, battery voltage, and read this.
Write Up: Monitoring the 6.0L PSD.
I know about the money thing, dont we all.
southend is offline
post #5 of 8 Old 07-10-2012, 01:54 PM Thread Starter
Belt Fed
HHB Guns's Avatar
Write Up: Monitoring the 6.0L PSD. - Ford Powerstroke Diesel Forum
Ok...Hooked up my bluetooth reader and downloaded the powerstoke PID's from torque and Hooked everything up...The truck voltage was about 11.5 volts when I started it up and it stuggled to start for the first time today but did start on the first start. Dumb me after the fact monitored the FICM and it was steady at 48 and I turned it off again and when started the second time the voltage was about 13.5 and the FICM never dropped below 47.5 during starting.
I also ran codes and came up with two.
P0401 EGR insufficient flow detected
and P132B Unknown
I was told from the previous owner he did the EGR delete but I honestly have no clue how to tell.
I guess I need to see if I have a battery short somewhere and check my charging system. Dont really know what I need to do about the codes.
Henry H. Bryant
AKA: Beau
HHB Guns, LLC
FFL 01/ Class 3 SOT
10" Superlift
40" Interco SS-M16
24" Dubs
Bully Dog Cold Air
EGR Delete
MBRP Exhaust
HHB Guns is offline
post #6 of 8 Old 07-10-2012, 02:03 PM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
11.5v is too low and I believe that is what is causing your hard starts. Load test your batteries at an Auto parts store to see if they are good!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #7 of 8 Old 07-12-2012, 07:18 PM
p132b is turbo boost control A performance. whatever that means, i have that code right now plus 10 more codes.
oilfieldtrash6.0 is offline
post #8 of 8 Old 07-12-2012, 09:53 PM
Quoted: 2 Post(s)
Did a quick search and the P132B could be sticking turbo vanes. It was recommended to take apart the turbo and clean it.
If the egr is in fact deleted the P0401 is nothing worry about. As far as i know the only way to get rid of that is with a tuner.
Ill check my voltage in the morning when i fire up the truck but i agree with the other guys 11.5 is a tad low.
One other thing to check would be ICP pressure it could be bleeding down while it sits. Im not sure how accurate/quick the torque app updates since it is bluetooth but it should be above 500psi to start.
Edit: watched the voltage on my cts and it showed 11.5 key on engine off and dropped to 10.5 while cranking, it did fire right off though.
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
