6.0 died no restart - Ford Powerstroke Diesel Forum
Old 07-08-2012, 08:54 AM
6.0 died no restart
I am dealing with a stock 2006 f-250 6.0 that died on the road and will not restart. Showing trouble code p2290 injection control pressure too low. HP oil pump and regulator a good place to start?
Old 07-08-2012, 01:19 PM
I just had this same issue. Injector control pressure regulator had failed.
Old 07-08-2012, 02:10 PM
Lpop, icp sensor/pigtail, hpop. You can disconect the icp and se if it starts to do a quick check on the sensor. Do you have a monitor to see icp pressure or voltage?
Sent from my SCH-I500
Old 07-08-2012, 04:40 PM
6.0died, no restart
No monitor, a local mechanic is going to check it out tomorrow. He has a good rep and has helped me in the past.
Old 07-10-2012, 05:40 AM
Any updates?
Old 07-10-2012, 08:04 AM
If your truck died and won't restart that means that you don't have enough oil to run the high pressure oil system.
