"Siren" sound - Ford Powerstroke Diesel Forum
Old 07-07-2012, 09:19 PM
"Siren" sound
We are taking the truck from Alaska to Missiouri hauling 2 motorcycles in the bed and a 6x12 Uhaul in tow. not really that much weight. As we were leaving, the code for underboost came on and we determined that the EGR valve was bad. It was covered in carbon and was stuck open. We replaced it but now we are hearing a loud sound, almost like a siren, everytime we go up a long hill. Same sound whether in tow/haul mode or not. It almost sounds like a fan kicking on. All the gauges look good. No spikes in temp or anything. Stock gauges. Any help would be appreciated. Almost back into the US and i wont be able to get back on here until then.
Old 07-08-2012, 07:14 AM
Exhaust flex joint cracked/lose clamps, turbo boots loose/busted.
Sent from my SCH-I500
Old 07-08-2012, 07:23 AM
Powerstroke Techie
I've seen a bad gasket on an egr valve do this. Basically any exhaust leak between the heads and the turbo can give you a whistle noise.
Old 07-08-2012, 08:52 PM
UPDATE:
The sound seems to fluctuate with the RPM. Higher the RPM, the louder the sound. Also, the AC seems to be running non stop. Even when I have it in what i assume is just the vent. Maybe its just that? It seems like it'll make it to Missouri where I can have it checked out. I'll keep updating with whatever I find out.
Old 07-13-2012, 06:32 PM
Powerstroke Techie
If you have your a/c on the mix setting where it mixes between vent and floor it will run the a/c. Look in your owner's manual if you don't believe me. And it will also run the a/c on either defrost setting.
Old 07-13-2012, 06:49 PM
I believe he is saying the "vent" setting, that will not run the compressor, it just lets fresh air in.
Old 07-13-2012, 06:50 PM
Originally Posted by kneedragger627 View Post
UPDATE:
I'm still saying this.
Old 07-13-2012, 07:30 PM
Powerstroke Techie
Some people call the mix setting vent.
I fully agree that it's an exhaust leak before the turbo.
Old 07-14-2012, 02:13 PM
I called a ford dealership on the way down and talked to a service tech. To him it sounded like some kind of fan cooling off the clutch since it was working harder to pull the trailer. What do you guys think?
Old 07-14-2012, 06:19 PM
Powerstroke Techie
I never thought of that, but I have heard the fan kick in dragging around some trailers with a 6.0. I guess I wouldn't have described it as a siren though. But it makes perfect sense to me. I guess I missed the part about pulling a hill with a trailer.
