Problems with turbo after oil & egr cooler install. - Ford Powerstroke Diesel Forum
Old 07-07-2012, 04:37 PM
I installed a new oil cooler, egr cooler, blue spring upgrade, new intake gaskets and any other gasket that is required doing such a job. After I was done and took the truck for a ride I had no boost. After a few minutes the turbo finally kicked in but just didn't seem right. I also noticed a whine coming from the turbo area and I also now have a code P0132B. Before I replaced the coolers I had no CEL and the truck and turbo were fine. I also have a noise coming from the turbo area that sounds like a hissing noise but it comes and goes while it's idling and driving. Anyone have any ideas?
Old 07-07-2012, 07:42 PM
is your up pipe aligned correctly? I'd check that as it's pretty common for do it yourselfers to not align it properly where it connects into the turbo.
Old 07-07-2012, 08:17 PM
I did have trouble aligning the up pipe. Tomorrow I am going to loosen the turbo bolts and try to align it again.
