2007 6.0 died at a stoplight, now no start - Ford Powerstroke Diesel Forum
Old 07-06-2012, 09:06 AM
SO i have an issue with my bone stock 2007 6.0 liter...stopped at one light, and i couldn't get it to accelerate until i revved it up in neutral, then put it back in drive and i was able to go. shortly after, (less than two miles), i stopped at another light and it just shut off. It will crank, and try to fire for about a second, then stops firing.
All this happened after four hours of steady highway driving, pulling a 7000 pound enclosed trailer at about 75 mph. I didn't overheat, no leaks noticeable, no odd smells or noises.
I got it towed to a shop in rapid city, south dakota called Rapid Diesel. I had to leave it there and rent a pickup to keep going, i work in the oilfield as a drilling consultant and was running behind to a well, so i had no other option but to get going.
An ideas about what is wrong, i need to know quick so i can get it fixed and back on the road, and to make sure this shop doesnt blow smoke up my ***.
Again, this is a bone stock 2007 6.0 liter, auto transmission, 64000 miles, 4x4 xlt.
Old 07-06-2012, 09:12 AM
HPOP fitting or maybe a FICM issue.
Old 07-06-2012, 09:21 AM
Thanks a bunch for the quick reply -
HPOP fittings, do you mean the ICP, IPR, and STC fittings?
Old 07-06-2012, 09:39 AM
Yep STC fitting... If the truck dies in flight then its most likely the STC fitting.
Old 07-07-2012, 11:02 AM
Thanks for your help, shop called back last night. They replaced the ICP sensor and it started right up.
Old 07-07-2012, 12:23 PM
Powerstroke Techie
Feedback Score: 3 reviews
If it's an oil leak it may restart cold. Hopefully they didn't just throw an ICP sensor at it.
Old 07-07-2012, 03:09 PM
Before the repair it wouldn't start hot, cold, warm, or anywhere in between. Batteries were non-issue, I even tried jumping it in case the voltage was too low.
