My truck randomly would not start one day after work so after some research I unplugged what I believe to be the ICP sensor on the right side valve cover. Tried to fire it up and nothing happened. Once I plugged it back in, she fired right up. Before I purchase a new one, is there anything else I should take into consideration as far as the truck not starting. Once I plugged the ICP sensor back in and drove it home it sat for about two weeks. I went to start it up the other day and now when it starts, it starts off with a big single lope or bellow if you will, then returns to normal idle. The check engine light is now on but I'm sure I just triggered that by unplugging the ICP.
Let me know what you guys think.
Thanks.
Thanks.
